door internals - FirebirdV6.com/CamaroV6.com Message Board
door internals
  • door internals
    will the window regulator of manual door will be the same as an electronic i need the window regulator the part that has like little teeth on it the ones at the end broke and my window doesnt roll up the whole was? will a manual door one fit?
    Re: door internals
    anyoneeeeee
      Re: door internals
      I assume you're replacing the whole assembly. Don't try to take it apart because that spring is really strong and can take a finger off if you're not careful.
      It should fit but you'll have to punch a hole through the door panel for the crank in which case the panel will be ruined if you decide to put the electric regulator back in.
        Re: door internals
        You might try the info in this link first. I had a similar problem and was able to find a solution without doing anything drastic:
        http://shbox.com/1/adj_window.html
          Re: door internals
          Make sure your very careful with the regulator like dobie said. My brother replaced his in a cavalier and the thing shot through the garage window and about another 50 feet from there.
          I replaced my window motor and think god I didn't have to take the regulator out.
            Re: door internals
            the part that i need is the star shaped one the one that has like little teeth the ones at the end broke so that part i need. so it should be the same right for electric and manual
              Re: door internals
              Just call a dealer and see if the part numbers are the same...
                Re: door internals
                i have actually been looking for this.. everytime we get a hard rain water leaks in and has blown about 3 rear drivers side speakers.. due to water damage..
                2001 Camaro 3.8 A4
                1991 3000GT VR4
                2001 Mitsubishi Eclipse GS
                  Re: door internals
                  ima call the dealer and ask im guessing the part i looking for should be the same
                    Re: door internals
                    If you can post a picture of problem, it will help in finding a solution.
