Mine is off but i forget if i had to take the panel off that says camaro first.The reason i need to know is because my parts are being painted and i would like to know if the panel that says camaro can go on before the rear cover is put on, or does the rear cover go underneath that panel?
Everyone who has removed rear bumper cover please help
Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,Tags: None
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...6 minutes ago
