underdrive pulley installation.... - FirebirdV6.com/CamaroV6.com Message Board
  • underdrive pulley installation....
    got the ASP crank and alternator set. how the heck do i get the old pulley off the alternator? I cant do much because theres no way to keep it from turning. ideas?
    1979 Z28 Camaro, 1 of 10,000 Factory 4 speeds. <br />1994 Camaro Sport Coupe, M5<br />Best ET: 15.31@91.5 (25 hp NOS)
    On my auto, I removed the torque converter shield and used a screwdriver to prevent the gear from turning.
    I believe Haynes says to put manuals into 5th gear...
    <b>Cheers!</b><br />Scott<br />1994 Camaro 3.4L V6<br />Flows, Underdrive Pulley, and a 180 Thermo
      an impact wrench will take it right off
      2000 Camaro 3.8 v6 M5
      Flowmaster 80 series muffler, B&M ripper shifter, SLP grille
        Andy is right. You're going to need to use an impact - for the alternator and the crank nut. (haha.. crank nut).
        It's A LOT easier than "trying" something else. It will just save you the headache if you use an impact.
        Zobe
          First just so your aware do a search. This topic has come up many times before. To answer your question you can place a screwdriver or something solid that won't bend as you slowly loosen the bolt holding the alternator pulley in place. Just be carefull not to bend the fan blades of the alternator. You can hold it in addition to having a solid metal piece keep it from moving. The same goes for tightening the bolt for the pulley. As for the crank the best choice is an impact wrench. You can use it for the alternator one as well but I had no problem with the alternator one.
          [ March 21, 2003: Message edited by: Skullcamaro ]</p>
          1994 Camaro<br />3.4L V6 Automatic<br />K&N FIPK&Gold Oil Filter,Ravin Performance Exhaustw/Dynomax MandrelBent3\"I-Pipe&S Pipe&Catco 3\" HiFlow Cat.,ASP Crank and High AMP Alternator,U.D. Pulley Set, Bosch Spark Plugs and Oxygen Sensors, Taylor Wires, B&M E.ShiftPlus, 160 thermostat,Zexel Torsen L.S.D., CSI Remote Mount Electric Water Pump & Temp. Controller & Flex Hoses, ALM. Drivshaft, Diamond SubFram Conn.<br />COMING SOON: 350 or 502 RAMJET ENGINE & Big Block Hood<br />NJ V6 F-Body Club<br /><a href=\"http://tristategm.com/NJFbV6/\" target=\"_blank\">http://tristategm.com/NJFbV6/</a><br />Street Lethal F-Body Association <br /><a href=\"http://www.slfba.com./index.html\" target=\"_blank\">http://www.slfba.com./index.html</a>
