what are some things that wouldnt let it come on? is there a way to no if the compressor is bad? thanks
a/c compressor isnt coming on
Re: a/c compressor isnt coming on
Originally posted by 97v6firebird View PostOnce it drops below a certain pressure point the compressor doesn't come on so you don't damage it. If you re-charge it and it starts working you have a leak somewhere like cam98aro said.
Originally posted by cam98aro View Postcheck the switch that plugs into the compressor then
Originally posted by 95firebird3.4 View Postok so i hooked a volt meter to the plug that goes into the compressor and it not getting any power. but the relay is getting power. is there anyway i can hook direct power to the compressor to see if its working?
im assuming you checked for resistance on the compressor side, and volts for the connector side?
you should be able to short the connection out to get the compressor to work.. if it does anyways
Originally posted by cam98aro View Postrun a direct line to the battery
personally i dont recommend doing that, a new connector on the compressor side shouldn't be too expensive, and its better than messing something up
