Ok, I am in need of some serious help here cuz I am stumped with this engine vibration (85 2.8) that I think has been there for quite a while. The vibration is apparent all across the rpm band but it expecially doesn't sound good when revving past 3000. You can even notice a distinguished shake to the car at idle (really noticeable in the dash pad, shifter and seat).
I recently noticed that the harmonic balancer was screwed as you could see it wobble so I thought that has to be it! NOpe......even though the rubber ring was half way out and the outer ring was definitely shifted off centre, not a bit of difference in the vibration :eek: The balancer wasn't new (from wreckers) but it looks great and now when spinning is completely true.
I checked the timing tonight and it was at about 20* (not sure how since I set it at 10 last fall) so I shifted it back to 10 and it ran even worse! There was a bad throttle delay and choking which made it hard to get it into 1st. So I put it back to where it was for now since it runs better.
Now I am stumped, what are some other problems that could lead to this vibration???? I am going to check compression, spark and vacuum tonight and will post what I find to see if that helps any. I have been told that V6's naturally have vibration but this just doesn't seem right to me
I have put so much time into this car and now it is treating me like ****.
Can anyone help point me in the right direction?
greatly appreciated.
