so i clicked my highs on last night they come on fine but then when i go to click them off they wont go of the control arm feels broken. any way to turn them off?
high beams stuck on
Re: high beams stuck on
Originally posted by nascar24jd View PostYou can also pull the lower dash panel and actually see the high beam switch. It has the little rod attached to it. You should be able to move it by hand.
Make sure the small metal rod is centered in the high beam switch. If the turn signal stalk feel broken and loose, remove the little cover that surrounds it. there is another flat cover behind it that the tilt wheel lever goes through, if you have tilt. pull that flat plate out and there should be a small loose piece of plastic that attaches to the other end of the high beam rod and the turn signal stalk rides up agaisnt this. If the plastic piece is broken or the rod has slipped out of it, the stalk will just flop around and not control the high beams. Sometimes when this happens the rod also pops out of the high beam switch under the dash. You will need to reinsert it in the switch first before reattaching it at the stalk.Last edited by poncho1961; 09-17-2008, 07:43 AM.
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...8 hours ago
