Alright, I've noticed that as I get lower on gas, the car seems to run abit rougher. A bit hesitant for WOT acceleration, seems like it's kinda lugging around, not cruising like usual. Every time I gas up, it almost seems like a whole different car. Could this be a sign of my fuel pump going? If not, any idea? I usually try and gas up aorund 1/4-1/2 tank, to help keep the pump lasting, but I did run it close to E last time.
Fuel pump going?
Re: Fuel pump going?
I would just check your fuel pressure and see what it is. And when you check it with the car off after idle see how long it takes to go down, should take more than a couple of minutes to go back down.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
