Fuel pump going? - FirebirdV6.com/CamaroV6.com Message Board
Fuel pump going?
  • Fuel pump going?
    Alright, I've noticed that as I get lower on gas, the car seems to run abit rougher. A bit hesitant for WOT acceleration, seems like it's kinda lugging around, not cruising like usual. Every time I gas up, it almost seems like a whole different car. Could this be a sign of my fuel pump going? If not, any idea? I usually try and gas up aorund 1/4-1/2 tank, to help keep the pump lasting, but I did run it close to E last time.
    ~97 3.8L V6 Camaro~
    A few things
    Only Member of Team Hooker?!?
    Re: Fuel pump going?
    probably there is a lot of crap floating around your tank, and when you get low, its clogging your filter/sock
      i 2nd that... might wanna drop it next time its almost empty and check it and clean it if there is alot of junk down there..
      2001 Camaro 3.8 A4
      1991 3000GT VR4
      2001 Mitsubishi Eclipse GS
        I would just check your fuel pressure and see what it is. And when you check it with the car off after idle see how long it takes to go down, should take more than a couple of minutes to go back down.
        • 187shark
          by 187shark
