oil light on - FirebirdV6.com/CamaroV6.com Message Board
oil light on
  • oil light on
    So I have searched and I didnt really find anything that anwserd my question. My low oil light came on yesterday.It was a little bit low so I added some and it went off. Then it came back on and the oil level is still perfect. Now it will come on but somthimes it will go out then come back on after i start my car. I scaned it at auto zone to see if it would help but it had no codes. What do you think I need to fix and how hard do you think it will be to fix? thanks brian
    I've had this exact problem. You need a new oil level sensor. It costs around $30 and is a very easy fix. It's right on the side of the oil pan, you disconnect the electrical connector and unscrew the sensor, and vice versa for installation. The reason it is off when you restart it is because it doesn't check the level when the engine is warm.
      I take it you have to drain the oil to install this sensor?
      My oil light pops on during hard cornering and will not shut off til I restart the motor.
      Black \'96 RS Camaro, 3.8 V6 Series II, M5, Stock 200 HP, 204K miles! Stock \'91 Firebird 3.1 V6 automatic w/ overdrive. 266,400 miles on it. \'83 Pontiac Trans Am,305 LG4, Cowl Induction,Borg Warner 5 Speed,T-Tops,Gale Banks Exhaust System:$800 obo
        It makes most sense to do it when the oil is drained.
          yup I am doing it today amd dping and oil change at the same time
            well where can I get the sensor i went to autozone, pepboys, ext and no one has the low oil sensor for my 1995 firebird 3.8. where can i get it in need it asap thanks brian
              I checked all over, and the only place I was able to find one was at Napa.
                ok cool thanks
                • Andy H
                  Transmission removal help!!
                  by Andy H
                • 2.8 Bird
                  Abs inop
                  by 2.8 Bird
                • fishin
                  by fishin
