AC/Heater Fan Noise - FirebirdV6.com/CamaroV6.com Message Board
AC/Heater Fan Noise
  • AC/Heater Fan Noise
    So there is an extremely obnoxious, relatively loud noise that comes directly from behind the glovebox area when I turn my heater/ac fan on the 3rd or 4th highest setting. it sounds like an awful buzzing noise and gets worse the higher the fan setting. I took off the glovebox and the noise seems to be eminating directly from a round, black cylinder shaped thing (about 3-4 inches in diameter with an orange tube coming from the cylinder itself). my question is, what the hell is that thing? is that the evaporator? anyone have a part number on it in case it needs replacing?
    <a href=\"http://home.comcast.net/~smpuskas/\" target=\"_blank\">http://home.comcast.net/~smpuskas/</a><br /><br />3A C-Fiber Pedals<br />Free Ram Air Mod + K&N<br />RK Sport Air Temp. Module<br />Flowmaster American Thunder 2.5\' Cat-Back<br />Chrome/Red Shifter<br />White Rally Stripes<br /><br />Audiobahn 12\' AE1200 Sub<br />Bazooka EL 1500 Class D Amp
    Re: AC/Heater Fan Noise
    that is mouse wheel that sucks into your system to move the heat and a/c.
    WAWA-A-HOLIC
      Take the fan motor out. It is really easy. There is probably some debris in there. Mine had some dried up leaves in it and it was very noisy. I took out the leaves and now it is nice and quiet.
        Holy hell the fan was literally half full of leaves. Cleaned all the garbage out of there and sweet fan silence! And it blows a lot harder too, unlike my ex-gf.
          I'm glad it worked out for you.
            wtf???
            WAWA-A-HOLIC
              Good advice, I think I have something in mine as well as my 3-4 setting makes some buzz like noise, I will take it out and clean it!
              1999 Pewter Camaro M5<br />Y87 Performance Package, Sport Appearance Package, Diamond Clears<br />Factory SS Hood, Free Ram Air Mod, Whisper Lid w/ K&N Air Filter<br />CarSound Cat 94009, B&B Tri-Flo w/ Quad Tips<br />BMR SFC, BMR STB, KVR Blank Rotors, Hawk HPS Pads<br />Black Painted Calipers w/ CAMARO Decal, 245/50 Dunlop SP Sport 5000<br />20% Rear 35% Side Tint, Red Reflective Inlays, Invincishield<br /><b>Young girls avert their eyes, weak men tremble, Ford dealers faint.</b>
                rotfl
                yea i get that noise too, might have to take a look. How did you get to it?
                  Pop out the glovebox, unscrew the few screws/plastic holders that hold the foot panel up, and there will be a round cylinder with 3 screws I believe. Unscrew them and your mouse-wheel fan will fall out and probably a bunch of crap along with it. YUCK! Clean that sucker out and enjoy the silence and a little bit cleaner air :)
                    hahahaha thats so random
                    2001 Firebird 3.8L
                      ROFL, hahahahah....maybe you needed to clean her out....
                        Same noise here, does it's easy to remove the blower?
                          does anyone have in pics on how to get it out. I see a round box, but I don't see any screws holding it in?
                            Sounds like it'd be a simple write-up for someone to do. And definitely a common problem with our cars. Guess I need to address that awful sputtering noise mine makes.
                            '99 Camaro
                            '04 Saab 9-3 Aero
                            '90 Audi Coupe Quattro
                              I found the screws, and yes it was full of leaves and dirt, man :banana:what a big difference. I actually have more than one speed on the HVAC now.:rock:
                              • Andy H
                                Transmission removal help!!
                                by Andy H
                              • 2.8 Bird
                                Abs inop
                                by 2.8 Bird
                              • fishin
                                by fishin
