I just put in the RK sport lid and a K&N filter. after resetting the computer and driving around for like 20 miles I figured the car had adjusted to the new airflow rate. so i shut off the car, and went back to work [img]smile.gif[/img] (so esy to install, I did it on my break at work) when i started the car to go home, I noticed that the car was idleing at almost 1k rpm. I remember it idleing closer to 500 before. So my question is... is this normal? I mean I didnt do anything wrong, did I? any input would help. I am so nervous about installing/ changing stuff on my car. She's just too damn technical.
stronger idle
it may have not adjusted the idle fuel curves and is dumping a little too much gas into the engine causing it to idle slightly faster
id say give it a week and see if it clears up, if not im not sure
i do know that after burnouts my car idles fast...i think its just not cutting fuel just rightR.I.P \'99 Firebird, you will be missed<p>New toy - 2001 GSXR-750, Yoshimura Exhaust, Power Commander, Rebuilt Airbox
Mine did, and still does the same thing after installing my K&N Fipk... the weird thing is the car will pull itself up real steep hills at idle after releasing the clutch! The K&N has over 7k miles on it and no change... tell me if you find a solution.97\' Red Camaro V6<br />::::Mods::::<br /> -Borla Single Cat <br /> -K&N FIPK<br /> -High Flow Cat<br /> -G2 Aluminum Drive Shaft (1 Peice)<br /> -G2 Trailing Arms<br /> -H&R Racing Springs<br /> -BAER Bump Steer<br /> -Bilstien Racing Shocks<br /> -Hurst short shifter<br /> -Eaton Posie Diferential<br /> -.373 Gears<br /> -NOS 85 shot<br /> -NOS Purge<br />(n/a) 1/8th Mile ET: 9.4 @ 81mph<br /><a href=\"http://members.cox.net/nitrous/index.htm\" target=\"_blank\">http://members.cox.net/nitrous/index.htm</a>
i like the sronger idle, it adds a little more rumble to the normally quiet red lights [img]smile.gif[/img] But I was just curious if it was normal... and from y'alls's experiences it is, so good! I'm just glad I have everything installed the way it should be. thanks guys!
What is a average idle for our cars. Mine has always idles at about 900 rmps and it has about 60K mile on it and its a 97.\"DRive it like you sTole it\"<br />RIP<br />Black 97 Camaro RS A4 (Y87)<br />3.42 LSD, Flowmaster exhaust(3in),<br />Slp Cold air intake Stage3 weight reduction (removed spare and jack)<br />\"Now a question of ettiquite, do I give you the *** <br />or the crotch?\" <br />~Tyler~ (FC)<br />!!!!NEW Ride Silver!!!! 03 WRX \"stock\"
mine did the same thing after the install, that's been two years ago. i was usuming that it was normal. i didn't complain she didn't break so we are happy! [img]graemlins/burnout.gif[/img]98 camaro 3.8 (THE PUNISHER)<p>JET STAGE II/B&M SHIFT PLUS/TAYLOR WIRES/SLP LOUDMOUTH w-3\" s- pipe/SLP CAI/SS MESH GRILLE/160 STAT/DERALE OIL COOLER<br />FLEXALITE TRANS COOLER/ 3.42-ZEXEL-TORSEN/KONIG MONSOON & KUHMO TIRES/MANUAL FAN SWITCH/1le sway bars & poly/KYB AGX SHOCKS/H&R SPRINGS/LS1 ALUMINUM DRIVE SHAFT/rk sport headers<p>WAITING FOR INSTALL:ssm heads,cam,3 angle valves/trans go shift kit
I must be the low one. I have the lid/kn combo and I idle at a lowly 650RPM [img]smile.gif[/img] The only time my car sounds like a V8 since it's so low. :D Start turning the wheel hard (make the engine work...plus having the A/C on) drops it to 500RPM [img]smile.gif[/img]
On your high idle...don't worry bout it...like you said, it'll make it sound louder. ;)
by RPDRed6Up for sale is my 2001 Chevrolet Camaro 3.8 in need of some TLC and help. I’ve owned this vehicle the past 18 years (since 2006) and it’s been very...4 weeks ago
