Would a bad oil pressure sensor casue my oil pressure gauge to be pinned over 80psi. I checked my level and its good.
oil pressure
Re: oil pressure
Is this at idle, crusing or WOT, but that really is high. A bad oil pressure sender could be at fault.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: oil pressure
I would check it out, I see 60 at idle and when driving around alot 40-60 WOT and around 40 at idle, only when it is real hot though.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: oil pressure
Yes, if the sender is dead it will pin the needle on the high side.... at least on my other cars it has. I don't know if the oil gauge on ours is controlled by the computer or if it's a direct connection to the sender. You could try unplugging it and jumping the wires to see if the needle moves.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
Re: oil pressure
It's going to be pinned no matter what. The sensor is probably dead, or there is a break in the circuit. The needle won't move until you test it or possibly replace the sensor.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
Re: oil pressure
I have a similar problem, except after my engine warms up and after maybe 20 minutes or so my gauge goes down to 40 sometimes lower at idle. This has been since my last oil change, my manual said i could put in 10w30 as long as the temp was hotter than 0F out, level is fine, and pressure always picks up with the throttle. Same thing?
Re: oil pressure
Originally posted by chevy the kid View PostSame here. With 5w30 oil pressure is 65 cold. 40-45 hot at idle and 55-60 in throttle. Never up to 60 hot.
I've try 10w40 and pressure is 50 cold and 45 idle hot. never up to 50...
i will try 5w40 i think, i can't find 10w30 in france
anyways with 10w30 in my car, it is 60 at cold idle, 62 when driving cold, then goes between 45-50 while under 2000 rpms
Re: oil pressure
Originally posted by cam98aro View Postare you sure you didnt write that opposite?
I know with 10w40 the pressure should be more than 5w30 but it's not the case.
So i think it's a sensor problem.
I have exactely what you have in pressure with 5w30. Just when the car is very very hot pressure is 35-40 at idle
Re: oil pressure
i think its your sensorHeady Navy Blue Metalic<br />Heady Catback Flowmasters<br />Heady Bilstien HDs, PAnhard rod, LCAs,SFCs<br />NGK\'s and MSD Wires, K&N flowin + Smooth Bellow<br />Y87 3800 GT Performance.<br />I love the way this car makes turns!<br /><br />1989 black Camoaro RS. R.I.P.
