help with O2 Sensor - FirebirdV6.com/CamaroV6.com Message Board
help with O2 Sensor
  • help with O2 Sensor
    OK, my check engine light came on so I took me car by advance and had them scan it and it pulled the code P0133 wich I was told on another forum is the O2 sensor in the drivers side manifold. Well I replaced it tonight and my check engine light is still on. So, my question is did I replace the right one, if so, do I need to reset my computer and if so how? Thanks
    1998 Camaro V6 A4, plugs and wires, 160* thermo, SLP Cold Air intake, whisper lid, dleted air silencer, K&N, Magnaflow cat-back, deleted cat
    Reset the computer... do it by leaving the battery unplugged overnight.
      That, or just have the auto store clear it with their code reader.
      1998 M5 3.8 Mystic Teal Camaro<br />Flowmaster exhaust, Pacesetter headers, 3\" cat, 3\" S-pipe, whisper lid, ram air, Spec Stage 1 clutch, Poly Trans mount, Walbro 255LPH. Numerous appearance mods.<br /><br /> <a href=\"http://www.cardomain.com/ride/2130533\" target=\"_blank\">http://www.cardomain.com/ride/2130533</a>
        If you infact replaced the correct sensor and that is the problem then the light will turn off in a few days by itself. Either of the two ways listed above will also clear the code
          ok, I had exactly same error last week after bump on the highway. on the turn to the nearest shop check engine light gone. I still scanned it - P0133. had that erased and nothing. havent replaced the sensor because sensor is not always the fault. Do you guys know what could be causing that problem?
            i have started carring my code reader in my car.
