my z28 idles at 1.. but my firebird v6 idles at 2.
is a 98 3.8 firebird support to idle at the 1 or 2 mark?
Re: is a 98 3.8 firebird support to idle at the 1 or 2 mark?
it should be idling at 750 rpm, which is halfway between the mark just below the 1 and the 12002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
Does it seem like the engine is reving high? Or is it a regular idle? When you tap the gas does it go away or does the rev stay higher?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
If the 98 was not drive by wire, and the RPMs are steady, but high, I would check the IAC. I've had two of them die on prior cars and it results in a high but steady idle.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
so i cant adjust the idle.. right?
how do i check the IAC? what else should i check?
i made sure the little part for the idle is on correctly.
then cleaned some other part. new pcv valve. cleaned the maf sensor. it does get a code for the egr valve.
Since it is a 98' you can adjust how much the TB blade is open at idle, it is on the drivers side of the TB. There is a adjusting nut that allows how much the TB blade closes, just unscrew it alittle to see if it helps, You can't adjust the IAC, you can take it out and clean the carbon off of it, whichs works most of the time. But I would check the adjusting nut for the TB blade.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
A fluctuating idle is probably not the IAC, then. The fluctuation is probably the computer activating the IAC to try and compensate for whatever the real problem is.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...15 hours ago
