On a 98' 3.8, what is the normal operating temp if you sit idle at a stop light for about 5 mins? I have a 180 TSTAT and it works fine, but when I sit @ a light it goes up rather fast, but once I get moving it comes back down. And the bottom reads 160 and the top 260....with three notches in the middle. What are the temps at those other notches, hell I may sound novice but I have no fuggin' clue
[ March 22, 2003: Message edited by: Christian ]</p>
-235/4517 Chrome Mondera Solaris<br />-Hornet remote start-keyless entry<br />-Pioneer 8400/CD/MP3<br />-2 Audiobahn 10\'s in custom box<br />-Flowmaster exhaust-SLP CAI-*180<br /><br />Never underestimate the predictability of stupidity....Tony from \"Snatch\"
The temp gauges in our cars are the most inaccurate gauges in the world! :rolleyes: My temp gauge reads the same as stock when I have the fans programmed for the 160º thermo... however, Autotap shows the accurate temp reading everytime.
The temperature sending unit for the dashboard and the temperature sending unit for the PCM are in two different locations. One is located in the water pump housing, and the other is located on the bank 1 cylinder head. Since the cylinder heads are the hottest part of the engine, it's no wonder why usually Autotap, Freescan and Datamaster show a lower PCM nominal temperature reading than what you read on the dashboard.
At certain running conditions, the difference between the two temperature sources can differ as much as sixty degrees. Use the temperature sensor in the water pump as your guide for actual coolant temperature.
Big cam. Big stall. Big nuts.<br /><br /><a href=\"http://www.streetlethal.net/vids2/joenastycam.MPG\" target=\"_blank\">Idle/Rev Clip.</a>
<blockquote>quote:</font><hr> Originally posted by Jason McCallister:
Just do the math.... subtract the 1st number from the 2nd and divide by 2. Subtract the 2nd number from the 3rd number and divide by 2.<hr></blockquote>
Wouldn't you add the two numbers and divide by 2.
<blockquote>quote:</font><hr>Originally posted by Christian: On a 98' 3.8, what is the normal operating temp if you sit idle at a stop light for about 5 mins? I have a 180 TSTAT and it works fine, but when I sit @ a light it goes up rather fast, but once I get moving it comes back down. And the bottom reads 160 and the top 260....with three notches in the middle. What are the temps at those other notches, hell I may sound novice but I have no fuggin' clue
[ March 22, 2003: Message edited by: Christian ]<hr></blockquote>
I have a stock Thermo and my temperature barely even moves, once it's warmed up. 99% of the time it's like 2mm left of the 210° verticle mark. And when it's starts gettin hot from idling a while, it moves like a mm to the right, but still not pass the verticle 210° mark.
1999 Pewter Camaro M5<br />Y87 Performance Package, Sport Appearance Package, Diamond Clears<br />Factory SS Hood, Free Ram Air Mod, Whisper Lid w/ K&N Air Filter<br />CarSound Cat 94009, B&B Tri-Flo w/ Quad Tips<br />BMR SFC, BMR STB, KVR Blank Rotors, Hawk HPS Pads<br />Black Painted Calipers w/ CAMARO Decal, 245/50 Dunlop SP Sport 5000<br />20% Rear 35% Side Tint, Red Reflective Inlays, Invincishield<br /><b>Young girls avert their eyes, weak men tremble, Ford dealers faint.</b>
