how do you change the turn signal switch - FirebirdV6.com/CamaroV6.com Message Board
  • how do you change the turn signal switch
    hey guys have a 94 maro and when i turn the left turn signal on it dosent spring back to turn off.. anyone know how to change this?
    Re: how do you change the turn signal switch
    maybe the bulb's burnt out...check that first. If that isn't the case, then replace the flasher. Both are <$10 fixes, so get at it
      Replace the spring on the turn signal switch. It's very common that they break.
        The Cancel Cam could be broken, its just flimsy plastic, its under the lock plate.
          its not the bulb or flasher cause they were just replaced and they flash it just dosent turn off after i make the turn i need to do manually... how do you change the spring??
            Remove the steering wheel and lock plate, and the clock for the air bag. The spring is in the top of the switch. You can also check the canceling cam while your right there. The spring and the cam would be dealer items.
