So Im having a local shop do my fuel pump, I don't want to hack my pans all up to get to it and I don't have all the tools to drop the axel and exhaust off myself. Labor is going to cost me $300. Question is what pump should i use? Im probably going to go OEM I've found a few on ebay and my big question is will the pump for an ls1 work fine? Are there any different connectors or anything like that?
If you have time to get one, lots of folks here like the Walbro 255 LPH pumps, as they can support future mods. But there is a little modification that needs to be done to make it work. I think the stock pumps are junk, mine died at 49K miles and lots of people on here have had them die early. My other cars have all had the pump last the life of the car.
