Testing injectors?? - FirebirdV6.com/CamaroV6.com Message Board
Testing injectors??
  • Testing injectors??
    What kind of tool would be needed to tell if an injector isnt working properly??and could a bad injector cause a light pinging???
    Re: Testing injectors??
    You can probably use an advanced scanner - but you'd have to bring it to a shop
    Leonard
    www.fquick.com/96V6Junkie
      try unpluging the one you think is bad if the noise goes away you found it
        You can use a mulitimeter and use the ohm setting, just put one prong on each side and the injector should be between 12-20 ohms. This will tell you if it is working , but doesn't tell you if it is clogged. I had a clogged injector for about a year before It was found and replaced. Would throw out PO300 all the time. I replaced just about everything until it was finally found by accident.
          what were the symptoms of your clogged injector ssms5411 beside the code??
            Actron Model CP7819 Fuel Injector & Harness Tester
            I got mine a few yrs ago, helped find 2 dead injectors when I was doing the 3800 swap. Cheap price, and more inportantly, it works. With injector testing, you can trigger an injector once or multiple times (3 clicks)
            2013 Ram 1500 Big Horn
            94 comero 3.4
