i dont know if this goes here but as of today my car started over heating. Its really cold outside like 46-50 degrees F. The radiator fan is running so other than that im lost. It wasnt just overheating by a little but the temp went up all the way in a matter of 5-10 min of drivng. Help!!!
Overheating??
Re: Overheating??
coolant was a little low, added some, problem is still their......i checked the oil with the dipstick and its fine too....the radiator hose going to the thermostat is hot but makes a thump every 3 seconds and shakes a little, normal? oh my coolant has become a brown mush, could that be clogging it and not letting the coolant circulate? any way to check for those gasket leaks you mentioned? sorry for this being so long but she's my DD and i dont want to drive it like this
Re: Overheating??
Are you using Dexacool or are you using green antifrezze?, brownish color would be a sign of oil in coolant. But if it is dexacool, I think that sh!t always looks nasty. Thermo would be a good place to start. How high did it go up to? Was it in the red on the dash?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Overheating??
I would think that an immediate, sudden overheating problem would be a stuck thermostat. That would be the first thing to check.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
Re: Overheating??
i am forever grateful to you guyz, thanks it was the coolant, i put some in but nothing i guess it was a little clogged and became unclogged with the new coolant and now shes all better. She stays right under 210 :) bought the thermostat just in case. Thanks guys if things start up again ill be back.lol
Re: Overheating??
Originally posted by Rob Bell View PostI would think that an immediate, sudden overheating problem would be a stuck thermostat. That would be the first thing to check.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
