update on the 89 - FirebirdV6.com/CamaroV6.com Message Board
update on the 89
  • update on the 89
    Called the garage today. Car has been siting there since the 17th. The only thing they've done is run it daily to use up a FULL tank of gas. Then I was told they put in an additive to clean the top of the engine. Why differentiate between the top and bottom. Wouldn't it clean the whole engine. They also mentioned something with the induction system. So far they said it has been running good but they wanted to keep it a day or so longer. Is this something I'm going to have to go through every few months? They did say they were getting some readings that weren't up to par but I will know more when I get the bill because I just can't remember what he said.
    Re: update on the 89
    the "top" means they are referring to your cylinder's
    and bottom basically means your oiling system
    they probably just put seafoam in it
      I had mentioned the sea foam to the guy that handles the service on the car and he said he never heard of sea form. What's your opinion as for me having to do this every couple of months?
        the GM Top end cleaner is also a good product. I remember yrs ago when I had my 82 Datsun 200SX, I had the injectors cleaned & they disconected the fuel lines 7 ran the stuff right through the schrader valve.
        2013 Ram 1500 Big Horn
        94 comero 3.4
          i dont remember your problem, so i have no idea
