I have a question about my rear defrost. Only about 1/4 of the little "lines" (defrosters) works. Anyone else ever run into this problem? It's just a really small thing that I'd like to get fixed, but I don't know how to go about it other than taking it somewhere. Any suggestions?
Rear Defrost
This topic came up a few weeks ago. Check the two connectors inside the rear window first, they are located on either side of the rear window near the top. Check to see that they are making a good connection. If it's making a good connection, then check the little wires that run across the inside of the window and see if any of them are broken/split. You have to look closely because the break is probably hard to see. If there is a small break, go to your nearest auto shop and look for the rear defrost repair kit. It's a fairly simple procedure.
-Marcsigpic
