relocating coil packs - FirebirdV6.com/CamaroV6.com Message Board
  • relocating coil packs
    For those of you who have removed the engine brackets....where did you relocate your coil packs to? or how did you mount them....I know the bracket has an arm that holds the plate that contains the ICM and coil packs....also if you could provide pictures of what you guys did as well it would help....
    Re: relocating coil packs
    my coil packs are on my firewall now.
    http://www.bowtiev6.com/
      how did you attach them there....and do you have a picture of it?...I'd like to get rid of my lift brackets and clean it up a bit if I can....
        I got rid of the bracket that has an arm that goes to the front. That's just open now, the coils are still held in from the bracket by the valve cover. I've never had any problems with it that way.
        ~97 3.8L V6 Camaro~
        A few things
        Only Member of Team Hooker?!?
          the coils are held by one bolt that is attached to the lift brackets? how did you get rid of that and have them still over the valve cover?
            IIRC, there's also one that goes around the valve cover, bolts into the block and then has 2 studs coming up that the coil mount goes on. That's all I have holding mine on.
            ~97 3.8L V6 Camaro~
            A few things
              In this one you can see one of the studs I'm referring to:
              ~97 3.8L V6 Camaro~
              A few things
                hmm....I dont recall having that when I replaced the valve covers and had everything apart about a month ago....
                  thats all mine is attached to...i got rid of my egr too hahaha
                  Y87 Package
                  MANUAL CONVERTED, Pro 5.0 Shifter
                  Pacesetters, Magnaflow Cat, Cutout, Flowmaster
                  MOGOB APPROVED!
                  BONE APPROVED!
                  VANBIBBER APPROVED!
                  KRISTEN APPROVED!
                  Vice Prez.
                  Team Black...TEAM EMO
                  Come on kids! Get a Calendar!
                    here is a quick shot I dug up
                      97rs4life I actually really like that....how did you manage to keep that up there? did you drill into the firewall? Is that safe?
                        yes I used a bracket and attached it to the firewall, then attached the coil packs and ICM
                          whats directly behind there if I drill into it? and what kind of bracket did you use?
                            did you have to tune for it to go away, or did you just take it out?
                            Team NoVa
                              Your firewall then dash wiring and such. A small sheetmetal screw is fine. Bracket is a 90* corner bracket found at any local hardware store
                              Yes or you will have an SES light on all the time
