For those of you who have removed the engine brackets....where did you relocate your coil packs to? or how did you mount them....I know the bracket has an arm that holds the plate that contains the ICM and coil packs....also if you could provide pictures of what you guys did as well it would help....
relocating coil packs
Project Cars | How To Guides | Scratch Repair | Synthetic OilTags: None
Re: relocating coil packs
how did you attach them there....and do you have a picture of it?...I'd like to get rid of my lift brackets and clean it up a bit if I can....
I got rid of the bracket that has an arm that goes to the front. That's just open now, the coils are still held in from the bracket by the valve cover. I've never had any problems with it that way.~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
Originally posted by RadRacer View PostI got rid of the bracket that has an arm that goes to the front. That's just open now, the coils are still held in from the bracket by the valve cover. I've never had any problems with it that way.
IIRC, there's also one that goes around the valve cover, bolts into the block and then has 2 studs coming up that the coil mount goes on. That's all I have holding mine on.~97 3.8L V6 Camaro~
A few things
hmm....I dont recall having that when I replaced the valve covers and had everything apart about a month ago....
thats all mine is attached to...i got rid of my egr too hahahaY87 Package
MANUAL CONVERTED, Pro 5.0 Shifter
Pacesetters, Magnaflow Cat, Cutout, Flowmaster
MOGOB APPROVED!
BONE APPROVED!
VANBIBBER APPROVED!
KRISTEN APPROVED!
Vice Prez.
Team Black...TEAM EMO
Come on kids! Get a Calendar!
97rs4life I actually really like that....how did you manage to keep that up there? did you drill into the firewall? Is that safe?
yes I used a bracket and attached it to the firewall, then attached the coil packs and ICM
whats directly behind there if I drill into it? and what kind of bracket did you use?
Originally posted by Firebirdkid96 View Postthats all mine is attached to...i got rid of my egr too hahahaTeam NoVa
Originally posted by LETZRIDE View Postwhats directly behind there if I drill into it? and what kind of bracket did you use?
Originally posted by flamingchicken View Postdid you have to tune for it to go away, or did you just take it out?
