3.4 LIM P&P (pics) - FirebirdV6.com/CamaroV6.com Message Board
3.4 LIM P&P (pics)
  • 3.4 LIM P&P (pics)
    http://img89.imageshack.us/my.php?im...fold017it5.jpg
    http://img259.imageshack.us/my.php?i...fold016mc5.jpg
    http://img374.imageshack.us/my.php?i...fold008st8.jpg
    For my epic build.
    Re: 3.4 LIM P&P (pics)
    Looking good my friend.
      thank you sir.
        Looks great, that should flow nicely.
        BTW can I borrow your guinea pig to help put my 3.4 back together ?? :)
          lol thanks man.
          You can borrow norbert but i want him back afterwards!
          and he's not much help, he just chews on wires and stuff.
            IS the last pic of the porting you did to the EGR passage? Are you going to use front wheel drive heads with it?
              did u do that urself?
                no, a fellow from NIagara falls (Whitethunder as he is known around cfv6 and ftv6.com ) is doin my upper and lower for me, he's a cool guy who knows what he's doin.
                and brian, the final picture is from the bottom of the ports lookin up (the little hole above is the injector hole) basically, it's just showing the port going into the heads, which by the way i'm getting a set port and polished to match (from ForcedFirebird over at ftv6)
                also brian, i am not using the 3X00 heads because then i wouldn't be able to use these intakes, as those heads require matching intakes.
                  That must be the exhaust cross over next to the port then. The FWD heads flow way better that the RWD heads do. You would probably run into problems with sensors trying to change intakes.
                    noooo, you run into fitment issues more than anything. RWD intakes go with RWD heads, FWD intakes go with FWD heads.
                    i realize the3x00 intakes flow better but i didn't want to make this thread into a hybrid discussion.
