3.4 LIM P&P (pics)
Re: 3.4 LIM P&P (pics)
Originally posted by rayosequis View PostLooks great, that should flow nicely.
BTW can I borrow your guinea pig to help put my 3.4 back together ?? :)
You can borrow norbert but i want him back afterwards!
and he's not much help, he just chews on wires and stuff.
no, a fellow from NIagara falls (Whitethunder as he is known around cfv6 and ftv6.com ) is doin my upper and lower for me, he's a cool guy who knows what he's doin.
and brian, the final picture is from the bottom of the ports lookin up (the little hole above is the injector hole) basically, it's just showing the port going into the heads, which by the way i'm getting a set port and polished to match (from ForcedFirebird over at ftv6)
also brian, i am not using the 3X00 heads because then i wouldn't be able to use these intakes, as those heads require matching intakes.
Originally posted by bigbrian442 View PostThat must be the exhaust cross over next to the port then. The FWD heads flow way better that the RWD heads do. You would probably run into problems with sensors trying to change intakes.
i realize the3x00 intakes flow better but i didn't want to make this thread into a hybrid discussion.
by ssms5411Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...1 week ago
by RPDRed6Up for sale is my 2001 Chevrolet Camaro 3.8 in need of some TLC and help. I’ve owned this vehicle the past 18 years (since 2006) and it’s been very...3 weeks ago
