I am having this weird problem where my car kinda cuts off then comes back on in split second while running. Mostly happens when you fully push down on gas, also I clanged my fuel filter which seem to help little but not much. Here is how I would describe the problem lets say I pushed down on gas where normal car would go paaaaaaaaaaa(change gear) aaaaaaaaaa etc, but mine dose (paaaaa aa aaa aaaaaa(change gear) aaa aaaaaa aaa. Lol this the best way I can describe it, yall got any ideas what would be wrong?
Weird Problem
Re: Weird Problem
That sounds like what my ignition modules did on my other two cars. Check your plugs and wires and if it continues, I would suggest pulling the coils and module and taking it to Advance Auto or Autozone or something and getting them tested. If it's not them, then check your fuel pressure. But if you have easy access to a fuel pressure gauge, I'd check that first since it's so easy.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
Re: Weird Problem
Originally posted by nascar24jd View PostAnd it usually happens at full throttle?
Help Plz
Hey yall still got the problem, where my car would stall and die at fullthrottle. Things I have changed are coils, plugs&wires, fuel pump, fuel filter, IAT sensor, MAP sensor. One thing I should add when I disconnected egr system's pipe it worked perfectly, but then after some more driving it came back. It gets to point when at ideal it start to stall and dies. Thank You in advance.
Re: Weird Problem
Originally posted by Richardcoelho View Postsounds like coils and wires, if i recently rained that could cause it, sometimes when it rains water drops into the engine and settles on the ICM and or wires but after it dries it works well so your problem could be a bad coil.
