ignition problems - FirebirdV6.com/CamaroV6.com Message Board
ignition problems
  • ignition problems
    how does the ignition mechanically work. when i turn the key i get nothing no lights come on nothing. but if i push on the buttom left of steering wheel while turning the key it will start. then when i go to turn it off the same thing the car will stay running again i have to push on the steering wheel. how do i fix this?
    Re: ignition problems
    It seems as though your Ignition lock is faulty
      where is that located? is it hard to replace? can i get it at a auto store?
        It is the key lock assembly that goes on the steering column where the key goes into
        • Andy H
          Transmission removal help!!
          by Andy H
        • 2.8 Bird
          Abs inop
          by 2.8 Bird
        • fishin
          by fishin
