When I replaced the spark plug wires I saw three rusty coil terminals. So I cleaned them with W-40 and let them dry. The car is working fine. Do you think is time to replace the coils? The car has about 110,000 miles
Coil corrosion
Re: Coil corrosion
I would sand them until they are shiny, then use dielectric grease when you put the boots back on. That will help prevent future corrosion. Don't worry about it, it happens.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
Re: Coil corrosion
yes, clean them, and they should be fine.
you should be able to tell when a coil goes bad.. but be forewarned, a coil that is under strain, meaning, a terminal that is rusty, or water in there, which is preventing your spark from being 100% effective from the coils standpoint can quickly make them go bad
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...18 hours ago
