Fuel Pump question - FirebirdV6.com/CamaroV6.com Message Board
Fuel Pump question
  • Fuel Pump question
    My fuel pump died however the sender is still working. Right now I have it running on an inline pump which is eternally annoying because of the loud humm it makes. I went the local bone yard and they had several 3.8s but none were a 99 on up mines an 01 with the larger tank. My question is can i just use the pump from one of the 97 on down cars and keep the sender body or is the whole assembly different becasue of the small tank.
    Thanks Dan-
    Re: Fuel Pump question
    btw the fuel pumps there are only 15 bucks so its not like im breaking the bank taking a gamble on a used pump.
      For the amount of work involved in replacing the fuel pump you'd be better off going ahead and just buying a new one. Just my opinion.
        ^ Not if he uses the access door method like me. http://www.geocities.com/formulapower2/fuelpump.html
        • Andy H
          Transmission removal help!!
          by Andy H
        • 2.8 Bird
          Abs inop
          by 2.8 Bird
        • fishin
          by fishin
