Hey group,
My car: 2000 Camaro 3.8L A4 89K miles
The other day I started having a mis-fire problem. Took it to Autozone to pull "check engine" light code. Cylinder #5 mis-fire. Suspecting the coil pack, I swapped the first 2 coil packs. If the coil pack is bad the problem would move to cylinder 6. Test drove the car and it ran fine. Drove it later and it was mis-firing badly again. It did not set a code but the check engine light flashed some during hard acceleration.
The guy at Autozone (for what it's worth) thought if the coil pack was bad it would affect 2 cylinders, in this case #2 and #5 as they are on the same pack. He also suggested the injector as a posibility.
Today I pulled the first 2 coil packs again and checked them with a meter. post to post was about 15.8K ohm (both) and open from the spade slot to the corresponding post. No help there. Put em back in (still swapped from thier original position). Took the car out and it ran fine, except for one time mis-fire during a hard acceleration. It was a long drive even on the highway.
I'm still suspecting the coil pack as that is the only thing I have messed with trying to diagnose this. The plugs are fairly new platinums and the wires are 6 m/o MSD's. The first and third coil packs may be original, they still have the cylinder #'s on them, but the middle one may have been replaced as there are no #'s. The middle one is for cylinder 2 and 5. You guys got any ideas??
Thanks
Russ
Thanks
Russ
