What are the signs of a bad alternator? - FirebirdV6.com/CamaroV6.com Message Board
  • What are the signs of a bad alternator?
    WHAT are the signs of a bad alternator?
    <b>*§*Julian*§*</b><br />*~*~*~<br />2000 Grand Prix GTP -Daytona 500 Edition (only 2000 made) - Supercharged 3.8L V6<br /><br />1998 3.8L V6 A4 Firebird w/ W68 package, Y87, T-TOPS!<br /><br /><a href=\"http://myweb.usf.edu/~jadidona/index.html\" target=\"_blank\">MY SITE - CHECK IT!</a>
    On my '94, the CHECK GAUGES light would always come on, along w/reduced volts on the meter (usually 10 or so). As it gets worse, you get ABS INOP lights, etc. If you have an A4, it may not want to shift into 4th (OD), since it's also electronically-controlled.
    2001 Onyx Black Camaro M5-Totalled<br />2005 Ford F150 XLT 5.4L<br /><br />\"To make peace, prepare for war.\"
      one other thing is that it will squeel really loud, that means the bearings are seizing! :D
      99 Firebird Vert, Pewter Metalic<br />Fast Toys Ram Air<br />Jet Stage 2 Chip<br />17x8 Mille Miglia Emotion II Plus\'<br />wrapped in 245/35/17 Yokohama A520<br />Rhino Perf. Exhaust<br />K&N air filter<br />check pics at:<br /><a href=\"http://www.fastrides.com/members/v6birdy/\" target=\"_blank\">http://www.fastrides.com/members/v6birdy/</a>
        Mine went out and the power gauge just slowly went down, the check gauages light went on, I was on the freeway, so eventually all the lights dimmed and went out, the abs inop and airbag inop lights were on, blinkers wouldn't work, so I pulled over and the idle was about 5000 RPMS. SO i just turned it off. If your charge dies while the car is running, its your alternator. If your car starts and runs fine, but won't restart, its your battery. But, hey go get it checked at checkers or autozone for free!!
        1997 Dodge Viper GTS
          It will not charge your battery enough to start your car, watch your pwer guage it will dip down, fluctuate alot with reves, will change charging range, without turning anything on or off and keeping motor at a consistent revs, and my ABS inop light ALWAYS came on, I never saw check guages or anyhting else.
          Check all your connections to everything, battery, and alternator, clean them up, then take the car to autozone they will test it for free.
            In some vehicles it will make the radio produce squeeling sounds when you are listening to it...it will be mostly heard on am stations tho.
            1995 Firebird 3.4L<br /><a href=\"http://kansas.no-ip.com/\" target=\"_blank\">My Site</a>
              if your tachometer starts freakin out and goin all over the place find a place to pull over because its about to go dead :D
              • 187shark
                by 187shark
