What's the difference between the 70's 3.8l and the 3.8l series 2? Also is anything interchangeable?
70's 3.8l
Re: 70's 3.8l
I thought we could use the turbo out of a grand national, but it was good luck finding one, and if you do...restore the damn thing...
Re: 70's 3.8l
ViperRider check out http://www.hotrod.com/techarticles/e.../photo_23.html. Something to slowly build too.
Re: 70's 3.8l
Originally posted by epsilon2322 View PostViperRider check out http://www.hotrod.com/techarticles/e.../photo_23.html. Something to slowly build too.2001 Firebird 3.8L
Re: 70's 3.8l
Originally posted by ViperRider View PostI can't imagine a 3.8 from the 70's being as efficient and putting out as much power as one from the 90's.sigpic
1997 Camaro RS A4
2006 Chevy Colorado
2003 Kawasaki Ninja ZX6-R
Re: 70's 3.8l
Originally posted by Shodown View PostBuick GN's can produce TONS more power than any car on this site ;) Thats partially why they can run 11's without breaking sweat and why so many can run 8's and 9's.
Why is it that GN's can make soo much power, but even guys who turbo our cars can't make that kind of power without breaking a sweat...
Re: 70's 3.8l
Originally posted by LETZRIDE View Postwhy is that though?... I thought we were supposed to have a revised version of that engine, therefore it is more efficient.
20+ years of R&D, large aftermarket industry, better intake manifold, stock turbo manifolds to work with, it was specifically made for FI etc.
Plus, at the time that they came out they were faster and made more power than anything GM, Ford or Mopar had to offer with 276 hp (which was underrated). Thats more power than the vette's were making in the 80's. So being at the top of the food chain, it got lots of attention from people who wanted to go fast thus creating a solid aftermarket with R&D. What is at the top of the food chain today? The cars with LS1/2/3/6/7 motors. Who gets all the attention for aftermarket and R&D? The cars with LS1/2/3/6/7 motors in them. See how that works?
They are also faster at the strip because they are lighter than the Fbody and can accept such transmissions like the turbo 350, 700R4, Powerglide etc. Do you know what those have in common? They can use a trans-brake. I only know of one V6 Fbody with a brake and its Tim King's race car. A brake is possible for our trannies, but its very costly.Last edited by Shodown; 12-05-2008, 01:36 AM.sigpic
1997 Camaro RS A4
2006 Chevy Colorado
Re: 70's 3.8l
Originally posted by Shodown View PostGee, I thought you'd know this. You seem to be the resident expert.
what do you mean trans-brake? what is that?
and what is R&D?
Re: 70's 3.8l
and what is R&D?
R&D = research and design
Trans-brake = locks 1st gear and reverse together thus making it able to rev up to the allowed stall RPM. It makes it possible to launch at high RPM's which is ideal for a turbo car so they can build boost on the line.
In drag racing, a transbrake is a setup installed in automatic transmissions which selectively places the transmission in first and reverse gears simultaneously, effectively holding the race car stationary as if the foot brake was applied. The transbrake is activated by the driver by applying electrical current to a solenoid at the transmission. With the transbrake engaged (transmission locked), the engine throttle can be increased to any position (opening) in preparation for launch without the race driver worrying about the car creeping forward. Milliseconds before the green light illuminates on the Tree the transbrake is released (by the driver releasing an electrical switch or by a delay box "timing out" originally triggered by the driver releasing an electrical switch) and the car launches forward, it's engine already in the higher power band and the transmission already in low gear.sigpic
1997 Camaro RS A4
2006 Chevy Colorado
Re: 70's 3.8l
so would you get the same result from a stall and a line lock?
Re: 70's 3.8l
Absolutely not. The foot brakes of a car will not hold the car back at high RPM's like that, the car will push thru the brakes AkA "pushing thru". The transbrake makes it mechanically impossible for the car to move until the driver lets go of the button.
I have a line lock and 3200 stall and I can still only get my RPM's to maybe 2200 before it starts pushing the car forward.
Guys with manual trannies will sometimes use a line lock to launch but they can play with the clutch simultaneously.sigpic
1997 Camaro RS A4
2006 Chevy Colorado
Re: 70's 3.8l
Originally posted by Shodown View PostAbsolutely not. The foot brakes of a car will not hold the car back at high RPM's like that, the car will push thru the brakes AkA "pushing thru". The transbrake makes it mechanically impossible for the car to move until the driver lets go of the button.
so would that transbrake not significantly reduce the life of the transmission, among other things since it simaltaneously holds the trans in 1st and reverse?
