160 degree thermostat replacement - FirebirdV6.com/CamaroV6.com Message Board
  • 160 degree thermostat replacement
    where is the thermostat on a 02 3.8 camaro?
    Re: 160 degree thermostat replacement
    if anyone could send me a picture or a video of someone replacing a thermostat in an f-body it would be greatly appreciated.
      Look at the pic below. Dont forget to get a new gasket.
      1997 Camaro RS A4
      2006 Chevy Colorado
      2003 Kawasaki Ninja ZX6-R
        thanks alot man. why do i need a new gasket? all i have is the thermostat
          unless the new gasket comes with the thermostat i ordered.
            they are only a few bucks for the local parts stores and stocked
            WAWA-A-HOLIC
              you should tune your PCM to lower the fan temps with that new thermostat
              1998 Chevrolet Camaro SS
              New Trans Setup:Rebuilt 4L60E, Yank ST2800 Stall, B&M Trans Cooler,
              TCI Deep Pan, Royal Purple, Trans-go Shift Kit. Should be done in January.
                They dont usually come with one, but if yours has never been changed then the gasket is probably going to be mangled when you take it off.
                1997 Camaro RS A4
                2006 Chevy Colorado
                  thank you all
