160 degree thermostat write up? - FirebirdV6.com/CamaroV6.com Message Board
  • 160 degree thermostat write up?
    can anyone give me instructions how to install a 160 degree thermostat on an 02 3.8 camaro? i know its easy but idk what to do with my coolant.. drain it.. dont drain it.. idk alot of people are saying different things.. so if anyone could just give me a complete write up on how to install a 160 degree thermostat in my 02 3.8 camaro, that would be great.
    Re: 160 degree thermostat write up?
    i am not trying to be an ******* bu tthis has been covered a million times there is a search button..
    2001 Camaro 3.8 A4
    1991 3000GT VR4
    2001 Mitsubishi Eclipse GS
      i tried to look, and its just everyone saying there opinion about if its worth it or not.. i cant find a write up on it:(
        you take 2 bolts out of the housing, let the fluid pour out, take the old thermo out, and replace the new thermo and gasket and put the 2 bolts back in, then fill the rad up with more coolant
        thats about it
          And I think you need to tune for it, otherwise you're going to get the SES light if the engine keeps running too cold as far as the PCM is concerned.
            You think right Rob. Your pcm also needs to know when to turn the fans on and off. So just putting a 160 thermo in without a tune will just make your car heat up to operating temperatures slower. Depending on where you live if it's your daily driver I don't think right before winter really hits would be a great time to install one.
            Regarding the actual install. If your scared to spill a little bit of coolant, drain a small amount. Otherwise, just pull the housing off. You won't loose a lot anyways.
            Secondly. Do Not attempt to install the thermostat until your car has been sitting for a long time and the coolant is cold or has lost pressure. You can check by squeezing the rubber hose.
            3rd.. I wrote this because I'm bored. This information is all over this website. Where do you think I learned from?
            TEAM C6V6
              how do i tune for it?
              and thanks all for the replys
                HPP3, HP Tuners, mail order tune or probably take it to the dealer.
                  No, they cannot.
                  HPT is your only tuning source.
                  1997 Camaro RS A4
                  2006 Chevy Colorado
                  2003 Kawasaki Ninja ZX6-R
                    No question about it. Get HP tuners. Not just for the thermostat but for any and every performance mod you plan to do in the future.
                    TEAM C6V6
                      I had mine for over 10 years and I have never seen a SES light come on. It really is ideal for force induction, but others here have it and they don't have force induction.
                      With 160* your car will operate at 165* temp. most of the time and prolong driving will bring it up to 180-190*. If you get stuck on a heavy traffic your temp will still go up to 210* and your fan will kick in.
                      When you replace the gasket though be sure the surface is nice and clean and smooth. Otherwise you'll experience coolant leak.
                        Ok, HP tuners is definitely used by anyone with forced induction because of the necessity. But to get the full benefits of mods like intake, exhaust, valvetrain, etc... HP tuners "unlocks" that power.
                        So I wouldn't nearly exclude HP tuners to just FI.
                        TEAM C6V6
                          what exactly does the hp tuner do? and how do i get it to do what its supposed to do?
                            www.hptuners.com
                            1997 Camaro RS A4
                            2006 Chevy Colorado
                              thanks
