Throwing Code P0125 - FirebirdV6.com/CamaroV6.com Message Board
Throwing Code P0125
  • Throwing Code P0125
    Hey Guys,
    So im throwing a code P0125 and any ideas on how to fix it.
    ive done some research and just wanted to hear any other ideas on how to remove this code.
    btw i have 2000 v6
    Thanks,
    Chris
    Re: Throwing Code P0125
    specs of car?
    do you have a 160 thermo?
    how often are you getting this code? i have had it happen on a different car before, but it was just an isolated case.. nothing to be worried about
      No real mods have been done to the car... basically just a stock V6 :( i know its a shame
      I have a 180* thermostat in there currently that i replaced about a year going on 2.... i just got the code the other day and it has not gone away.
      Thanks cam98aro for the advice, i hope it goes away, that SES light really gets on my nerves!!!!
        thermo's are only a few bucks. it's worth replacing
        WAWA-A-HOLIC
          You can check your thermostat with a pan of hot water and a thermometer. It should open when the temp in the pan reaches 180. Then if the code stays, check the temp sensor. You can check its resistance using the pan of hot water and comparing it to the thermometer reading. At x temp it should have y resistance. Watch it throughout the range all the way to boiling and make sure the resistance values are correct, and that it's a smooth transition.
          I would think those are the only two things that could cause a code.
            Thanks for the suggestions. The light actually went off when i was cruising today, but im going to try those suggestions to see if anything is broken.
            Thanks for the help. It was greatly appreciated :)
              personally, i wouldnt do anything unless it comes back again
              sometimes there can be just a freak code out of nowhere
              for instance, on my friends truck, his computer was used to him driving to work at 90mph every day, the location of his work changed, and his truck kept overheating because the computer wasnt turning the fan on
                I agree. See if the code comes back before you start worrying about it.
                • Andy H
                  Transmission removal help!!
                  by Andy H
                • 2.8 Bird
                  Abs inop
                  by 2.8 Bird
                • fishin
                  by fishin
