You can check your thermostat with a pan of hot water and a thermometer. It should open when the temp in the pan reaches 180. Then if the code stays, check the temp sensor. You can check its resistance using the pan of hot water and comparing it to the thermometer reading. At x temp it should have y resistance. Watch it throughout the range all the way to boiling and make sure the resistance values are correct, and that it's a smooth transition.
I would think those are the only two things that could cause a code.
Thanks for the suggestions. The light actually went off when i was cruising today, but im going to try those suggestions to see if anything is broken.
Thanks for the help. It was greatly appreciated :)
personally, i wouldnt do anything unless it comes back again
sometimes there can be just a freak code out of nowhere
for instance, on my friends truck, his computer was used to him driving to work at 90mph every day, the location of his work changed, and his truck kept overheating because the computer wasnt turning the fan on
