idle air control valve - FirebirdV6.com/CamaroV6.com Message Board
  • idle air control valve
    has anyone replaced an idle air control valve on their 94, 3.4 camaro? if so any help would be appreciated.
    thanks, burtcam, 1994 camaro
    I've replaced mine its a pretty simple 30$ part. two screws and its out pull it out clean out the inside where the spring goes in. Put new one in. But what exactly is the problem that is making you want to Replace that?. You might be wasting 30 bucks
    John<br />Flowmaster custom piping, K&N intake and filter, catco high clow cat, stage II clutch, More to come.<br /> <a href=\"http://www.cardomain.com/ride/2036060\" target=\"_blank\">http://www.cardomain.com/ride/2036060</a>
      i can't seem to get a smooth idle, the car has over 110,000 miles on it.
      burtcam
        I bought one for my 97 and could never figure out exactly what kind of screws those were. I have yet to change it. What the hell kind of screw is that? I tried everything I had and nothing worked on them.
        <a href=\"http://www.cardomain.com/ride/2093533\" target=\"_blank\">CarDomain Page</a>
          its a #15 torqe screw.
            Man the IAC might not help your idling issues Trust me I know i tried and it was a total Pain in the A$$ to find out where it was coming from.. First Check for a vacuum Leak check your hoses check for a loud hissing sound undernearth the Plenum That's where my leak was and had to replace the Intake manifold gaskett. But IAC from my experience and from what I'v heard doesnt really fix a rough idle.. also Check your throttle body as well throttle body gaskett. Plus you have alotta miles on your car like me. I have a 138k on mine so it actually won't hurt to change those gasketts anyway cause there probably pretty rough as it is with high miles.
            • Andy H
              Transmission removal help!!
              by Andy H
            • 2.8 Bird
              Abs inop
              by 2.8 Bird
            • fishin
              by fishin
