Definitely recommend this oil to everyone! Just went from 18MPG to 23; only difference was I changed to RP 5w30 oil. Plus, the motor seems to rev up smoother and a bit quicker. If you haven't done it yet, do it; it's worth the $8.50/quart
Royal Purple
Re: Royal Purple
I use RP in the engine and in the rear end, great stuff . Run Valvoline dexron VI syn. in the tanny. When that needs to be changed I will use RP in there. Look on ebay motors they have pretty good deals , I just picked up 12 qts. of RP for $88.00 shipped.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Royal Purple
Originally posted by cam98aro View Postdoes the money saved in fuel help or hurt you compared to the price of the oil
When the time comes, I'll be running RP in everything :).~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
Re: Royal Purple
Originally posted by Mighty Thor View PostI've been using Mobil full syn. with an added Lucas full syn. It worked pretty good, but I always wanted to try RP. I think I will next oil change.
Has anyone ever tried Redline full syn. I heard that's great too.~97 3.8L V6 Camaro~
A few things
Re: Royal Purple
I just got a case of RP 20w/50 for the $88 shipped on ebay. I was running 10w/30 but in AZ it doesn't get cold about 40-50 degress at night during winter and summer 110+ . So I hope this helps some, I know alot of people are against running 20w50 but I read up on it alot and even asked my dad who worked for GM for 40+ years and he said it should be fine to run.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Royal Purple
I used to praise Royal Purple 10W30 until it reached 500 miles before the oil change interval at the 3000th mile. I've used this since 2006 with mixed opinions. My daily commute would be 106 highway miles round trip so 2 yrs ago I thought I'd experiment with synthetics first with a Royal Purple oil change at the end of each month religiously.
Why at 2500 miles? I noticed after 2500 miles my oil gauge would slowly dip below whats normally expected and the needle at or below 40 PSI sitting in heavy traffic to a point it actually makes my idle rough and I have to rev it just to keep the engine happy. I got fed up with the idle characteristics and in Summer 2007, I switched to Mobil 1 High Performance 10W30 and I'm much happier with the way it runs now. I wondered about the viscosity of RP after 2500 miles due to my commute primarily.
Another thing I noticed was the remains of Royal Purple in my engine messing with the new 5 quart infusion of Mobil 1 HP switchover. At times it did not idle right 'til the 2nd Mobil 1 HP oil change. It now runs way smooth after every Mobil 1 HP oil change for me therefore my Camaro may be just an isolated thing.
I have no ideas about Amsoil or other synthetics. I'm sure someone will write their experiences here soon. I also live in the Northeast where varying climate can affect oil life I'm assuming.
My Camaro has 275,000 miles now. Mobil 1 HP :rock:Black \'96 RS Camaro, 3.8 V6 Series II, M5, Stock 200 HP, 204K miles! Stock \'91 Firebird 3.1 V6 automatic w/ overdrive. 266,400 miles on it. \'83 Pontiac Trans Am,305 LG4, Cowl Induction,Borg Warner 5 Speed,T-Tops,Gale Banks Exhaust System:$800 obo
Re: Royal Purple
to 96rsalex- i feel you man i use fully syn mobil-1 (10w 30) but considering that your car has such high mileage the royal purple created too little friction which probably dropped the cylinder pressure which doesn't help since you already are loosing compression so probably if you go to a thicker weight of royal purple it may work better because it is a very well lubricated oil.
Re: Royal Purple
Originally posted by RadRacer View PostNever heard of redline.
Re: Royal Purple
my old man runs moblil 1 syn in his truck. he changes it every 6 months, regardless of mileage, and uses a fram filter. its a 1994 chevy c1500 with a 4.3 5 speed...313,000 on the odo. still drives it to work every day,and gets 20 miles to a gallon, no problems. i personally think the guy just takes good care of his stuff, i have never seen him dog on it, ever.Team NoVa
