will a slp manual fan control switch work with a hypertech powerstat 160 degree thermostat?
with the slp manual fan switch, can i turn it off and on anytime i want? or does it have to be manually set to a certain timeing to turn on and off with a tuner?
Do you guys think the 160 degree thermo and manual fan switch are worth installing?
yes it will work with that thermo, yes you can turn it on and off anytime, it doesn't have to be turned on and off with a tuner, hence the name "MANUAL fan switch".
Yes they are worth installing and go well with one another.
Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...
Up for sale is my 2001 Chevrolet Camaro 3.8 in need of some TLC and help. I’ve owned this vehicle the past 18 years (since 2006) and it’s been very...
