160 degree thermo sucessfully installed! - FirebirdV6.com/CamaroV6.com Message Board
  • 160 degree thermo sucessfully installed!
    :banana: woo!!!!!!!! first "real mod" for a noob besides dropping in a k & n airfilter :naughty: next mod CAMSHAFT :rock: HAHA kidding. not quite there yet :) but have a question.
    when it says somthing like "bleed it until air comes out and a little collant will come out" does this step have to be done? i didnt drain my coolant i just took the thermo housing out and a little anti freeze came out but not too much. then i refilled the coolant.
    so can not "bleeding it" damage anything? does this step have to be done?
    Re: 160 degree thermo sucessfully installed!
    Yes, you need to bleed the air out, or your temp will heat up. But I think if you let it sit over night it might bleed itself out. Then add coolant if needed the next morning.
      thx m8 :)
