oil change every 3000? - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    Re: oil change every 3000?
    As I said earlier, I change it every 3,000 miles. I do ignore the 3 month deal and I stick to 6 months maximum. My wife's car only get driven about 2,000 miles every 6 months. My car reaches 3,000 miles in about 4 months.
    When I lived in NY, I had a 110 mile round trip commute every day. With all of that highway driving I used to change the oil in the car every 5,000 miles. I ended up changing the oil about every 2 months and it was still very clean looking.
    • #17
      Originally posted by Bonemaro View Post
      I just change it when the car says it's due. I have no clue how many miles on average.
      Not sure about yours, but last I checked, my Camaro didn't have an "Oil Change" light......
      ~97 3.8L V6 Camaro~
      A few things
      Only Member of Team Hooker?!?
      • #18
        Not sure what years it's on, but there's a suggested Oil Change light that comes on based on a driving style, mileage, use, etc. Only seen mine come on once or twice, and that's because I forgot to reset it when I got the oil changed.
        Change my oil every 3,000 miles, give or take a couple miles. I'll go out and buy the stuff a couple hundred miles before time for the change so it can be done during a lunch break or something.
        '99 Camaro
        '04 Saab 9-3 Aero
        '90 Audi Coupe Quattro
        • #19
          yea i have an oil change light too. it comes on almost everytime i start the car but then goes off after like 30 secs to a min or so. it was doing that even after i got my oil change. guess it still needs to be reset. not a big deal tho.
          • #20
            You just need to reset it. Next time you get the oil changed, just hold down the button by the odometer for 30 seconds until the light flashes a couple times. It will also reset your trip odometer, fyi.
            '99 Camaro
            '04 Saab 9-3 Aero
            • #21
              When I reset my oil change light (when it comes on), I can go through 3 oil changes before the light comes back on. That means 9K between oil changes...
              Forget that...
              When I do my oil changes at 3K, I get 4 qrts back. So I burn roughly a quart of oil every 3K. It comes out dark and well, that to me means the light doesn't work.
              Mobil1 + Mobil Filter + Lucas Syn Additive.
              Oh, I got 271K on the clock btw...and run the hell out of my car.
              • #22
                yea i thought so thx.
                • #23
                  Forget that...
                  you have 271k miles on your car? does it still run strong? whats your 1/4 btw if you have one, and what are your mods?
                  • #24
                    Induction:
                    SLP Cold Air Panel
                    Sealed Air Box
                    Whisper Lid
                    K&N Filter
                    Smooth Coupler
                    Descreened MAF Sensor
                    Throttle Body Spacer
                    Ignition:
                    MSD Blaster Coils
                    Bosch Platinum +4 Plugs
                    Taylor Spiro Wires
                    Exhaust:
                    Pacesetter Headers/Y-Pipe
                    !Catalytic Converter
                    Vibrant Resonator
                    3” Custom Piping
                    Magnaflow Catback
                    !EGR
                    Drivetrain/Misc:
                    3.08s -> 3.73s
                    Open Diff -> Auburn LSD
                    Rebuilt Rear End
                    !ABS
                    B&M Transmission Cooler
                    160* Hypertech Thermostat
                    SLP Manual Fan Switch
                    Interior:
                    Rear Seats/Belts Delete
                    Corbeau TRS Seats
                    !Spare/Jack
                    !Sail Panel Speakers
                    Pilot GT Steering Wheel
                    Suspension/Chassis:
                    Bilstein HD Shocks (Original Version)
                    Eibach Springs (Pro-Kit)
                    BMR Shock Tower Brace
                    BMR Sub-Frame Connectors
                    BMR Anti-Sway Bars
                    Pro-Stop Drilled -> Brembo Blanks
                    Hawk Pads
                    Speedline WS6 Wheels
                    Nitto 555 275/40/17 Tires
                    Tune/Electrical:
                    Hardwired Valentine1
                    VATS Bypass
                    Ignition Security Switch
                    PCM Tune by Texas Speed
                    Infinity Basslink
                    Infinity Kappa 6.5” in doors
                    !Antenna/Motor Stubby Conversion
                    Lots more...can't think of it right now.
                    Ran a 14.54 in Commerce when I had 190K afew years back. Still runs like a champ...got a slight hiccup (ignition coil probably going) but other than that, still runs like a bat out of hell.
                    I'm a tech so all my work is done by me...the last think I did was a failing belt tensioner.
                    ___________________
                    Pics
                    http://forum.camarov6.com/showthread.php?t=79766
                    http://forum.camarov6.com/showthread.php?t=87947
                    • #25
                      Induction:
                      SLP Cold Air Panel
                      Sealed Air Box
                      Whisper Lid
                      K&N Filter
                      Smooth Coupler
                      Ignition:
                      MSD Blaster Coils
                      Taylor Spiro Wires
                      Exhaust:
                      Vibrant Resonator
                      3” Custom Piping
                      Magnaflow Catback
                      !EGR
                      Drivetrain/Misc:
                      3.08s -> 3.73s
                      Rebuilt Rear End
                      !ABS
                      Interior:
                      Corbeau TRS Seats
                      !Spare/Jack
                      Suspension/Chassis:
                      BMR Anti-Sway Bars
                      Hawk Pads
                      Tune/Electrical:
                      VATS Bypass
                      Infinity Basslink
                      ___________________
                      Pics
                      wow dude nice. thats a pretty sweet 1/4 mile time for no heads, cam, sc, turbo, or nitrous. also with 200k plus miles on it. must be well maintained. :tup:
                      • #26
                        wow i just saw the car too SWEET BIRD. that is in such great condition. awsome :tup:
                        • #27
                          wow, that is nice. Im hoping to just drive mine till the wheels fall off, or till 300,000k. Impressive!
                          Team NoVa
                          • #28
                            Forget that...
                            wrong wrong wrong
                            the oil change monitor counts your engine rotations, NOT how many miles your car goes, it is working perfectly fine.
                            your car should only take around 4.2 quarts assuming you have a v6, i have no idea why you would be putting 5 quarts in
                            • #29
                              Check the manual... 4.75 quarts on 3.8 engines. I use Mobil's M201 filter...double the capacity of the M101...which constitutes the additional .25 qrts.
                              If it counts engine rotation...well, that's almost 9K miles of rotating.
                              I'm not aurguing with anyone...if y'all want to do 6-8K mile oil changes...do it. I work in a service shop...I see what happens.
                              I will NOT, or ever, do more than 3K per oil change...it gives me a peice of mind. $50 and 30 minutes is a small price to pay to drive your car for 10+ years with 300K on the ticker.
                              With all regards, everyone is able to change their oil when they want on their cars. I'm just adding my 2 cents...3K or 3 months. Nothingless for me...
                              • #30
                                BTW, thanks for the comments gentlemen.
