problems.....again - FirebirdV6.com/CamaroV6.com Message Board
problems.....again
  • problems.....again
    ok 96 3.8 5 speed recently fixed a missing problem (car gremlins unpugged #4 injector and cracked #5 plug) car been running fine then started going dead when you let off the throttle like stopping at a red light so i just quit stopping now when you accelerate not just w.o.t when i gets to 3500-4000 acts like it hits a rev limiter and chokes big time so ideas....? other than gallon of gas and match already considered that not enough insurance coverage.
    Re: problems.....again
    I would check the Idle Air Control Valve,Replace the Fuel Filter.
      my exact thoughts
        either help the op's question or don't post at all please, I will not tolerate any crap like what went on earlier
        http://www.bowtiev6.com/
          Coil packs? Full tune up, change all wires and plugs? Sea foam? Dirty Injectors?
          Start with the basics.
            i have no idea what your talking about but why was my post deleted, i didnt do anything??
              engine was built about 4 or 5 months ago (by me)new coil packs and board new plugs and wires check injectors seafoamed less than a year ago thanks for the input though
                just had a brain fart would an exhaust leak at the manifold cause this? because the night it started doing it i bottomed it out playing dukes of hazard(not literally) on a dirt road and broke on of the bolts connecting the pipe to the manifold and i havent fixed it yet due to the fact i ve got to drill it out and all that business not a terrible exhaust leak mind you but.....?
                  I would not think so, but I guess it is possible. Has it had this issue since the rebuild or did it run ok aftere the rebuild?
                    no this is a recent development it had amiss for a while as stated above but i fixed it ran fine for a while then started this fixed the exhaust leak thought maybe it was throwing my o2 sensors of but it changed nothing sounds better but still falls on its face during acceleration
                      well put some new wheels on it that that didnt help also i doesnt do it when its cold for first 10 min if running gets worse as it warms up
                        wheels dont help anything....
                        Team NoVa
                          go to a dealer and have them put a scanner on the computer. and have the mechanic watch the outputs of the motor as it climbs through the RPM's. that should tell you whats going wrong.
                            check your cat
                            Y87 Package
                            MOGOB APPROVED!
                            BONE APPROVED!
                            VANBIBBER APPROVED!
                            KRISTEN APPROVED!
                            Vice Prez.
                            Team Black...TEAM EMO
                            Come on kids! Get a Calendar!
                              yea that was joke as far as dealer looking at it im poor and im catless thanks though any more ideas?
