its basically stock but i have a 160 degree thermo and a k & n airfilter :naughty: i know i need a manual fan switch but besides that what does anyone suggest my next steps should be? and does it matter what order?
where do i go from here with my cars mods?
Re: where do i go from here with my cars mods?
EDIT just saw post
First: Exhaust....headers, cat, cat back ( do it all at once if your paying someone to do it)
Then, some type of CAI, depending on your car (what kinda car do you have?)
maybe gearing, aluminum DS after that.
since you wanna run 13s i would look at nitrous setup and/or cam
i have a 2002 3.8 automatic camaro. im trying to stay away from nitrous since the power can't be put out all the time. I just want to step on the pedal and the power to be there.
Originally posted by ava1219 View Posti have a 2002 3.8 automatic camaro. im trying to stay away from nitrous since the power can't be put out all the time. I just want to step on the pedal and the power to be there.
after u do full bolt ons, get some abbot heads and toss a cam in there and call it a day.
those 3.8's see mega gains from those abbot heads.
you won't hit 13's without going into the engine, or stripping out the car
with that said: cold air intake, aluminum driveshaft, posi rear w/gears, 3" exhaust, hi-flo cat, headers, subframe connectors, lower control arms, and then go into the engine or lose some weight.~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
Originally posted by RadRacer View Postyou won't hit 13's without going into the engine, or stripping out the car
Totally correct me if im wrong, im here to learn....Team NoVa
subframe connectors, lower control arms.
Originally posted by flamingchicken View Postso i have always heard that 3" exhaust is over kill. I have had two different guys at two different shops tell me that 2.5 is good for around 300-350hp. I had it on my bird for a while, and it pulled good after about 4800 rpms so i went to 2.5" and it was torque-ee-er (more torque-ee?) and i didnt feel any effects on top end performance.
so which do you suggest for my car a 2.5" or 3" exhaust? (since you have had experience driving with both)?
Originally posted by firebird19_99 View Postwhat are these, where do they go and what do they do now and will do better once upgraded?
lower control arms (LCAs) will get rid of wheel hop. http://www.umiperformance.com/201520
Originally posted by ava1219 View Postso which do you suggest for my car a 2.5" or 3" exhaust? (since you have had experience driving with both)?
also is your car an auto? anyways i would look into gears, 3.73s, maybe 4.10s. Also a stall converterLast edited by whitdog54; 12-29-2008, 02:37 AM.
