ugh...t-tops - FirebirdV6.com/CamaroV6.com Message Board
ugh...t-tops
  • ugh...t-tops
    ok... well, got in the car today, and my butt got wet. turns out the t-tops are leaking :mad:... looks like its leakin' on the front and rear facing parts... passenger and drivers side... im not sure though, but there is water there. man, i know leaking t-tops are a common problem, so what is the best solution to fix it? easiest and cheapest. can you bondo or epoxy it somehow?
    Re: ugh...t-tops
    Im not a T-Top expert but I would def suggest because this is what I did when my Conversion started leaking...Get some of this stuff called Black Silicone and find out where it's leaking from. The best way to do that ( Or alteast how I did it in my conversion ) is to take the top off and pour water down the lining of the stripping to see where it's entering your car at. When u find the hole give it some of that good ole Silicone and see how that works for ya...I guarentee if u plug the holes up and get in your car you'll be like :banana:
      Re: ugh...t-tops
      also check into some subframe connectors...works wonders for handling and will hopefully fix that leak and tone down any interior rattle
      pacesetters|full 3" borla exhaust|3" stainless e-cutout|slp cai & ram intake|c/f whisper lid|tbs|eibach|kyb|stb|sfc's|adj.lca's & phb|slp fan|b&m t5|180*|z06 17x9.5|8000k hids|hptuners|d/s rotors
      gone in body, but not in spirit
        Re: ugh...t-tops
        adjust the weather striping...or buy new
        WAWA-A-HOLIC
        • 187shark
          by 187shark
