help with s-10 - FirebirdV6.com/CamaroV6.com Message Board
help with s-10
  • help with s-10
    I changed the cat on my s-10 two months ago and the DTC P0420 Catalyst System Low Efficiency went a away. It just came back any ideas?
    Re: help with s-10
    bad cat? Guy on another forum bought a new high flow cat and had to replace it after 3 months....some times you just get screwed. Check the 02 sensor
      Re: help with s-10
      did you get a universal high flow one? If so did you use a o2 sim or does the s10 not have a post-cat o2?
      http://www.bowtiev6.com/
        Re: help with s-10
        it a oe cat and it does have a post cat o2 sensor. You guies think the sensors bad
          Re: help with s-10
          I changed the rear o2 sensor and Iam still getting the code any ideas? help
            Re: help with s-10
            any one?
