Car starts, runs for a few seconds, then quits? I need help! - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    Re: Car starts, runs for a few seconds, then quits? I need help!
    i've heard of people cleaning their intakes - works fine after that
    Leonard
    www.fquick.com/96V6Junkie
    • #17
      Originally posted by ajzcamaro View Post
      It just seems weird because I thought the IAC would cause erractic reving which I don't have. Either way I'm hoping this is all the problem is.
      when i removed my IAC to clean it, and after i had it back in, when i went to start my car, it cranked longer than normal, then started up for a few seconds, then stalled again.
      did that a few times until i hit the gas on startup
      the IAC does also cause weird rpm problems also
      its kinda like a choke in a way, where it will let air passed the throttle body, if yours isnt working correctly.. especially with this cold weather, it may be causing a quick lean condition, which the car cant compensate for in time, and it will stall
      • #18
        Update: I cleaned the hell out of the IAC valve, checked the TPS sensor, replaced the PCV valve, and extreme cleaned the TB and now the car is running correctly again. The IAC valve was sooo clogged up that it could not move. Now I've gotta tackle why my car acts like it runs on 5 cylinders every now and then. I think one of the coils have taken a dump on me since the plugs and wires are brand new.
        • #19
          either that or a bad valve stem seal, causing an oil fouled plug...ive had that happen before.
          Team NoVa
          • #20
            Yeah the old plugs had a little bit of oil on them but nothing major. I really think the coil is bad b/c one of the connection points looks burnt. I'm going to replace it today when I get home from work and see how that works out for me lol.
            • #21
              Good job on getting the IAC thing resolved.
              • #22
                Good thing too b/c I was about to pull my hair out. I went to the parts store yesterday and the clerk gave me two new coils for free since I go up there so much. Seems to have fixed the rough running problem for now.
                • #23
                  Good, sounds like your car is on the mend.
                  • 187shark
                    by 187shark
