I was just on my way home and noticed when i turned my heater on there was this burning/sweet smell comming from the vents. it didnt throw any codes and the engine was not over heated. it was around the 160-190 degree range. got home popped the hood and nothing seemed to be wrong. what could this be caused from and could this be dangerous?
burning/sweet smell from heater
Re: burning/sweet smell from heater
Usually that means you have a leaky heater core. If your windows start fogging up or you get coolant on your carpet that will confirm the leaky heater core.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
Originally posted by ava1219 View Posthow could i solve this, if this is the issue? and i recently installed a 160 degree thermo around a month ago. could this have anything to do with it?
Most purists are against this, but if your in a jam it can definitely get the job done. Sometimes temporarily and sometimes permanently.
Originally posted by speedyx14 View PostIf you find that it's a leak and can't fix it now, you could put some radiator stop leak in there. http://www.crcindustries.com/auto/co...?PN=401210&S=N
Originally posted by ava1219 View Postif my passenger side carpet isn't wet, does that mean theres no problem?
#1 - Are you losing coolant?
#2 - Is the carpet wet?
Originally posted by nascar24jd View PostDo not use Stop Leak. It will clog things that you do not want clogged. Just fix the problem
If your heater core has a tiny leak that just started it might not be enough to wet the carpet. Keep checking it. Maybe it was an outside odor like you mentioned earlier. You just need to keep an eye on two things here.
Originally posted by tmon930 View PostDo Not Put F*cking Stop Leak In Your Coolant!! Your Car Will Hate You!! I Will Hate You!! Purists My ***!! Your Radiator And Hoses Will Be F*cked!
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...10 hours ago
