burning/sweet smell from heater - FirebirdV6.com/CamaroV6.com Message Board
  • burning/sweet smell from heater
    I was just on my way home and noticed when i turned my heater on there was this burning/sweet smell comming from the vents. it didnt throw any codes and the engine was not over heated. it was around the 160-190 degree range. got home popped the hood and nothing seemed to be wrong. what could this be caused from and could this be dangerous?
    Re: burning/sweet smell from heater
    btw im a little overdue for an oil change...i never heard that it could cause this but who knows..
      Usually that means you have a leaky heater core. If your windows start fogging up or you get coolant on your carpet that will confirm the leaky heater core.
        how could i solve this, if this is the issue? and i recently installed a 160 degree thermo around a month ago. could this have anything to do with it?
          im hopeing there isnt a problem and just a smell from outside blew into my heater.
            Check your passenger side carpet. If it is getting wet then the heater core is on its way out.
              If you find that it's a leak and can't fix it now, you could put some radiator stop leak in there. http://www.crcindustries.com/auto/co...?PN=401210&S=N
              Most purists are against this, but if your in a jam it can definitely get the job done. Sometimes temporarily and sometimes permanently.
                thanks guys
                  if my passenger side carpet isn't wet, does that mean theres no problem?
                    Do not use Stop Leak. It will clog things that you do not want clogged. Just fix the problem
                    If your heater core has a tiny leak that just started it might not be enough to wet the carpet. Keep checking it. Maybe it was an outside odor like you mentioned earlier. You just need to keep an eye on two things here.
                    #1 - Are you losing coolant?
                    #2 - Is the carpet wet?
                      I didn't check if im loosing coolant yet but i did check the carpet and it is not wet. i started the car and turned on the heater and i still smell it but its alot less strong than it was before. tommorow i will have to check the coolant.
                        its really cold out right now and getting dark so i will check the coolant tommorow.
                          Do Not Put F*cking Stop Leak In Your Coolant!! Your Car Will Hate You!! I Will Hate You!! Purists My ***!! Your Radiator And Hoses Will Be F*cked!
                            It sounds like you have a leak somewhere. If your coolant level has dropped at all then you need to find the leak.
                              my friends dealership used to put pepper in peoples rads when they came in with leaks.. no joke
                              • 187shark
                                by 187shark
