What kind of fuel do you use - FirebirdV6.com/CamaroV6.com Message Board
  • What kind of fuel do you use
    What kind of gas do you use?
    Until recently ive been using the crappy stuff...or the button on the far left on the gas pump. And now my car runs like S*** and i got an SES light and im missfiring. So i switched to the expensive stuff (far right button) like the owners manual said and im hoping my car will start running better after i run about a tank or so of the expensive stuff. Also i was just wondering if anyone else has had this problem and if u have what did u do to fix it?
    Red 1998 Camaro 3.8<br />K&N and Home Depot<br />2 12\" JL W3v2 Subwoofers<br />-more audio stuff to come-
    At my gas station the pump on the far left was deisel.... I guess running that was a bad idea.
    Time to check:
    Plugs
    Wires
    Coils
    How many miles on your car?
    Oh yah, I use 87
    <a href=\"http://members.cox.net/95batmobile/d86f.jpg\" target=\"_blank\">Sinister Six</a> <br /><b><a href=\"http://www.cardomain.com/id/c_o_jones\" target=\"_blank\">Cardomain</a></b><br />--This doesn\'t change the fact that I am ~The Guru~ who still kicks puppies...
      i got 53K miles. On the gas station i go to the far left is just the crappy gas so i used the most expensive kind now and i dont know the octane level
      if my car doesn't start running better here within a week or so im taking it to the chevy dealer and ill have them see whats wrong and if its something with the coils, wires, plugs ill replace them
        i use 94 octane, just for the extra assurance i dont get water n all the other badstuff in the gas, drives a little better then 87 but nothin crazy significant
        94 Pontiac Firebird-V6<br />-NxWetKit,RamAir,MSD Dis4, Coils,&Wires,DynomaxExhuast w/testpipe,NittoDR\'s&DunlopSPort5000s,17\"CrEagleAl loys,TransgoShifKit/VetteServo<br />91 Jeep Wrangler-5.7 Chevy350<br />-6\"ProComp SuspensionLift,M/T BajaClaws35x12.5,& more goodies
          They're gonna charge you $70+ for a one time deal that you can either do for free, or time and time again for about $120.
          Either take it to an Autozone (Napa, Shucks, Checkers, Pep Boys, etc...) and ask if they can scan your codes. If you want to take the plunge, buy your own ODBII scanner (mine was $150 and has payed for itself 3 times over). If you are getting a multiple cylinder misfire then it's either the coil pack for that cylinder, the plug or wire.
          Coils - about $35 each
          Wires - $ 30 for cheapies at store - $60 for 8mm from any of our fine sponsors or thunderracing.com
          Plugs - cost is up to you.
            Might wanna read the manual again, because it says to use 87 octane (cheap stuff). Higher octane for a stock or mildly modded car is a waste of money. If you car runs better on high octane, then something's wrong.
            Matt
            1998 Mystic Teal Camaro M5
              Exactly. Leave the high octane to the engines that are made to use it. Find out why a F Body V6 has problems with 87 and fix it.
                pretty much the only reason you would need to use a higher octane gas is if your engine starts to knock.
                any other time is just a waste of money
                and any "gains" are 99% of the time in your head
                1994 white Firebird M5<br />Flowmasters, CAI, 3.73s, LSD, coated pacesetters, eibach pro-kit, bilsteins, hurst shifter, JVC stereo, 18\" C5 vette wheels, Kuhmo Ecsta ASX rubber<br /><br /> <a href=\"http://www.cardomain.com/memberpage/744299\" target=\"_blank\">http://www.cardomain.com/memberpage/744299</a> <br /><br />Coming Soon: Turbo!
                  I used to use 87 but i started using 93 and started getting around 20-30 miles more per tank.
                  Also i didnt want any 93 octane left in the tank before it went to the shop since my new engine will have raised compression from stock.
                  New:04 GMC Sierra 1500 RCLB 4x4 5.3 GU80 3.73\'s.<br />Truck pics<br />Mods<br />Go fast: Panel K&N filter and soon SS truck catback.<br />Appearance: Stull Billet grill,Weston Chrome step tubes,Rhino Chrome hitch step,ARE painted fiberglass cover,Silver star lighting.
                    i ran 87 to untill i started spraying, now i put in the highest i can get (91oct)
                    -Chris<br />2001 Pewter Camaro M5<br />Current Mods: NOS Dry Kit and a few others<br />N/A: 15.5@88.9MPH<br />N2O: ??? <br /> <a href=\"http://www.cardomain.com/id/jtusa69888\" target=\"_blank\">http://www.cardomain.com/id/jtusa69888</a>
                      91 is the highest you can get? Where you live?
                        I always say...."if ya gotta eat hot dogs....buy the best....Joyryd only gets the best the "pump du jour" has to offer. ;)
                        \"this isn\'t flying...its falling...with style!\"<br /> -Buzz Lightyear<br /><br /><br /> 96 bright red firebird, T-tops, monsoon CD Flowmaster catback dual exhaust <br /><br /> <a href=\"http://members.cardomain.com/joyfellowship1\" target=\"_blank\">http://members.cardomain.com/joyfellowship1</a> <br /> <a href=\"http://www.joyfellowshipchurch.com\" target=\"_blank\">www.joyfellowshipchurch.com</a>
                          I don't care what anybody says... I have always used premium and always will. I definitely notice a slight performance gain with the higher octane and jeeeezzzz fella's it's only 2 to 3 dollars more per fill-up. I pretty much use Chevron premium with Techron. I have no idea if that stuff really works to keep the fuel system clean but it seems to work well as I have been using it for years.
                          For what it's worth.
                          RD in AZ
                          RD in AZ<br />2001 V6 Camaro, A4, Mystic Teal<br /><a href=\"http://www.azfba.com\" target=\"_blank\">www.azfba.com</a><br /><br />Mods so far:<br /><br />Brand new wiper blades... Hah!!<br />T/A Diff Cover and Stud Kit<br />\"Dremel\" modified factory lid with K&N filter
                            Myself and AZv6camaro are both in Arizona. Thanks to the strict emissions laws and the damn fuel additives, the highest octane available here is 91..
                            RD in AZ
                              RD in AZ
                              That sucks alot man sorry.
                                6 days ago
