Anyone with a 98+ camaro step in plz - FirebirdV6.com/CamaroV6.com Message Board
  • Anyone with a 98+ camaro step in plz
    Hello!
    My oldest brother is interested in this 99 red t-tops camaro to buy. He just got a job, and hes fresh out of college, but he needs a car. It has 43XXX miles and was the owner of the dealerships wife's car. Very clean, exterior and interior. I just had a couple of questions for you guys.
    #1 It idles at like 600-700 rpm, is this normal? My car idles at 900. I let it warm up also, and it still does that. Just seems low to me?
    #2 The temperature gets to 200 DRIVING, is this too hot? Once again, my car never gets past 170, but I have the 180 thermo stat, new water pump.
    I don't see any oil leaks around the seals or anything, other then those two probs., its perfect.
    Anything else I should look for? The guy who is selling it told us he'll fix any problems we find before we buy it, b/c the right rear taillight has a crack, I noticed it because it had water in it. He's going to fix that ( buy a new one? not sure )
    Just let me know guys, I apprecaite it!
    I already checked rear window defrost, all the interior buttons/radio/speakers/ carpet and stuff, the paint on the body is great, it doesn't pull to any side when braking/driving, the ac is cold, can't think of anything else off the top of my head! Thanks guys!
    RedLineVSix <br />95 Patriot Red Trans Am, M6, 3.42\'s,no rear tires<br />(SOLD!)97 Silver Camaro 3.8 Liter A4 3.42 + LSD, 1pc DS, and one messed up speedo :)
    Regarding #s 1 & 2: sounds pretty normal to me. Assuming the Camaro is a V6, the factory thermostat is 195 degrees, so 200 is actually a little low. 210 would not be unusual for factory.
    The F-body tachs are noteable inaccurate. If the idle is smooth probably nothing to be concerned about. If it is not, maybe some carbon build up and needs cleaning. Don't forget to have the idle air valve cleaned.
    2001 Camaro M5 Coupe(1 of 2,737), no options, Whisper Lid, K&N Air Filter, Free Ram Air, MAFS Screen removed, SLP Manual Fan Switch, 160 thermo, DEE\'s T/B Spacer, EGR Block-off plate, IAT resistor, CAI to EGR air feed, B&M Ripper Shifter, SLP Replacement Grill, T/A Exhaust, SLP five spoke take-off wheels, BMR strut-tower brace, BMR Tunnel Brace, BMR 32/21 front & rear sway bars with poly, BMR Poly/Combo Rear Control Arms, Clear front & rear corners, HPP3 modified 87 Octane program.<p><a href=\"http://www.cardomain.com/id/red2k1\" target=\"_blank\">http://www.cardomain.com/id/red2k1</a>
      I dont know where my temp sits at, all I know is that it usually stops at the first 1/4 mark, I have never seen the 210 or above in mine.
      about the idel, the 3.8 seems to idel pretty low, and it is pretty quiet when running, I dont think that is a problem.
      I would run out and look at the temp thing more but it is 9*
      ~chris~ 98 Cayenne red Camaro 3800 A4, 3:08, T tops Borla cat-back, wisper lid K&N, Bilstine shocks, Dunlops all around. <br />AOL IM: chevyboyz24
        Always take a new car on the highway before buying it. When I first bought my 98 I did this and found that the tranny messed up at high speeds.
          my 98 idles at 900, so 6-700 is a bit low, but if it's smooth i wouldn't obsess over it. just mention it to the owner and ask him to check it out.
          you can\'t get off if you don\'t get on
            my 97 has always ran at around 215 :D
            [ January 19, 2003: Message edited by: 97chevycamaro ]</p>
            Dont call me chief.<br /><br />2001 Camaro Convertible Rs Replica<br />1991 Acura Legend
              thermostat + coolant mix being too thick with dexcool causes the temp issue.
              Its probably idling fine if it sounds smooth and normal.
              I like the 00+'s personally, better steering wheels :D
              2002 5-spd NBM Camaro
              Details: www.1lev6.com
                my 98 idles at about 780-800 on the autotap but the tach shows 1100...
                <b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
                  Sounds normal to me. Mine idles at 700 rpms unless the ac compressor is on, then it idles at 750 rpms. The temp sounds normal too. The needle on mine is always a couple of millimeters left of the center vertical line.
                  [img]graemlins/burnout.gif[/img]
                  1999 Pewter Camaro M5<br />Y87 Performance Package, Sport Appearance Package, Diamond Clears<br />Factory SS Hood, Free Ram Air Mod, Whisper Lid w/ K&N Air Filter<br />CarSound Cat 94009, B&B Tri-Flo w/ Quad Tips<br />BMR SFC, BMR STB, KVR Blank Rotors, Hawk HPS Pads<br />Black Painted Calipers w/ CAMARO Decal, 245/50 Dunlop SP Sport 5000<br />20% Rear 35% Side Tint, Red Reflective Inlays, Invincishield<br /><b>Young girls avert their eyes, weak men tremble, Ford dealers faint.</b>
                    If it is an A4, idling in gear at 6-700 RPM is typical and 200 is a normal on the 2000.
